Signalling Question
morgan306
On an PD6662/EN50131 system, if the system is activated followed by a tamper, would it send an intruder, followed by confirmed, or intruder then tamper?   I think confirmed, but I'd like to be sure as I have a grading exam tomorrow.
cheers!
Just had a look through my notes.
It should as James said send a tamper now if set, not an unconfirmed. However, if another detector triggers in the confirmation window it will send a confirmed is how i intemperate it?
I'm going to try it on a RI tomorrow,
Something that I am not sure on, however, when PD6662 is turned on with a Premier, it automatically selects the option of 'No confirm for device tamper', which makes me think that no confirmed should be sent
Tamp no confirm is only for the same device, so if the device goes active, then a tamper from the same device will not cause a confirmed alarm, however a tamper from another device in the confirmation window will.
Depends on the order, if tamper first then yes send tamper, if activation first then tamper from a different device, = Alarm + confirmed
dunno, it shouldnt a tamper isnt a confirm event now
but adrian knows more on the regs in his head than me
Only from the same device
amealing@texe.com
Head of Industry Affairs
Visit Our Website
Texecom
We had a site with a keypad and speaker in the 24 hour security lodge, they had a FA one night single activation.
The temp guard had no idea of the code so started trying different codes to shut the sounder up.
Ended up going tamper keypad (Galaxy 520) anyhow it sent a confirmed upon the tamper and got policed.
