Signalling Question
morgan306
Tamp no confirm is only for the same device, so if the device goes active, then a tamper from the same device will not cause a confirmed alarm, however a tamper from another device in the confirmation window will.
I don't believe this is correct.
A tamper from another device will send a tamper after the first intruder, the ARC will see the two pins and respond as a confirmed.
This is what happened to us.
Sorry i misunderstand what you are saying, what you have said should be confirmed, Alarm from device 1 tamper from device 2 = confirmed alarm.
What i have said is tamper from device 1 followed by alarm from device 1 or vice versa does not equal confirmed.
amealing@texe.com
Head of Industry Affairs
Visit Our Website
Texecom
Same here, I say this from experience.
To clarify.
Two Guard zones 007 and 008 (for example).
If 007 is triggered and goes active an intruder pin is fired.
Then if 008 is tampered a tamper pin is fired not a confirmed pin.
To clarify.
Then use proper signalling :D , pins should be shot, surviving pins should be shot again, and then  buried with the rest of the dinosaurs. If a tamper signal cannot contribute to a confirmed activation, what's the point of tampers? It's parts of the standards like this that are trying to educate the industry to stop using outdated nonsensical technology.
amealing@texe.com
Visit Our Website
Texecom
I am not complaining, I am explaining what happens. (on Premier panels, I might add!)
Either way the correct action is taken at the ARC, I see no issue.
Good, as long as we are happy, pins are still **** though
amealing@texe.com
Visit Our Website
Texecom
