rickvr6 Posted October 21, 2014 Posted October 21, 2014 Just installed an alarm at home but think I need a psu. It's got 3 rkp's, 1 bell and about 16 pirs also a wireless receiver. Need help on how to connect a psu.thanks
datadiffusion Posted October 21, 2014 Posted October 21, 2014 System make and model, PIR make and model? So, I've decided to take my work back underground.... to stop it falling into the wrong hands
rickvr6 Posted October 21, 2014 Author Posted October 21, 2014 Sorry it's a texecom premier 48 elite and pirs are texecom pristige TD and DT.
sixwheeledbeast Posted October 21, 2014 Posted October 21, 2014 It sounds overloaded. Simple as replacing an 8XP for a PSU200XP? Don't common the positives.
rickvr6 Posted October 21, 2014 Author Posted October 21, 2014 First alarm I've done so don't understand what don't common the positives mean. It's got 2 expanders on already so was just going to put a 2amp psu on.
al-yeti Posted October 21, 2014 Posted October 21, 2014 What are you planning to connect to the 2amp psu? Everuthing else will have the main system battery as backup in mains fail , if psu goes down whatever is on it will go down Hence as 6w says PSU200XP which has room for batteries, or something similar if you keep ur existing expanders a psu with an alarm output and battery back or something like that perhaps
rickvr6 Posted October 21, 2014 Author Posted October 21, 2014 Yes I was going to get a psu which has battery back up and power both expanders.
sixwheeledbeast Posted October 22, 2014 Posted October 22, 2014 Or buy a PSU200 and plug the existing expanders in with the 5-Pin KK crossover connector.
