not sure but whats that got to do with anything
im just trying to play h.264 files coded on a linux dvr on a linux pc
should not be hard but it is not working at them moment
i can use the concept pro dvr files of the same footage but there lower res images
really need to check this footage has copied to the usb stick thats all
i also juggling lots of other stuff so its hectic
maybe data , matt or james knows how?
, ive got the videos to open in the default video player in linux mint . sorted wish id tryed that 1st
vlc will not play them...
Default Ubuntu player seems fine with every format I have tried.
Posted (edited)
linux mint is a ubuntu mod that is more popular than ubuntu,they take all the spyware an bulk out of ubuntu , anyway point is im sure its the same player which works fine :proud:
i had just presumed it would not work as vlc didnt but i was wrong i shuda just tryed that 1st :)
theres nowt wrong with the secware unit james
im not putting the footage online but it looked fine on the pc good copy no frame drops that i noticed
Edited by EggyBum69
Your incorrect on many points there.
Never presume anything.
