sullym6 Posted November 25, 2014 Posted November 25, 2014 Didn't see this section so posted in the detectors section by mistake, might get more visability here Hi We have just had an extension which now covers an alarmed Patio door (2 Shocks and 1 contact) and also an internal Window (2 shocks). These have now been replaced with internal doors so I wanted to move the sensors to the extension which has 2 entrances with windows either side I can move the old patios door shocks to the main entrance which comprises of 2 large windows with french doors in the middle, so thats 1 shock per window and contact on the door. The side entrance has a single door with 2 smaller window panels, will the shocks be o.k for this or should I replace one of the shocks to a contact and then change the sensor via the panel to a contact The windows and doors are brown upvc so I am looking at some way to hide the cables but all the trunking I can find in brown is 25 x 16 which is a little large. I do have the engineer code for my system so hopefully with the help of the manual I should be able to make any changes I need. Thanks Sohail
james.wilson Posted November 25, 2014 Posted November 25, 2014 best way of hiding the cable is inside the extrusion of the frame. however check the window company permit this securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sullym6 Posted November 25, 2014 Author Posted November 25, 2014 Hi James thought about that but decided against it as if anything ever goes wrong I can see the window company blaming the alarm install. I have hopefully managed to get some matching trim pieces that I will use to put over the cables. Now is just what to do with the sensors, can I daisy chain the shock to a contact I understand they will be on the same zone but the main thing is the door will be protected better. The sensors are wired EOL so I guess I need to move the resistors to the last sensor Thanks Sohail
al-yeti Posted November 25, 2014 Posted November 25, 2014 Hi James thought about that but decided against it as if anything ever goes wrong I can see the window company blaming the alarm install. I have hopefully managed to get some matching trim pieces that I will use to put over the cables. Now is just what to do with the sensors, can I daisy chain the shock to a contact I understand they will be on the same zone but the main thing is the door will be protected better. The sensors are wired EOL so I guess I need to move the resistors to the last sensor Thanks Sohail Daisy chain as in series yes, but if sol isn't there enough zones or pairs to give an additional circuit?
sullym6 Posted November 26, 2014 Author Posted November 26, 2014 Hi al I don't want to mess with the panel so there may well be enough pairs for an additional contact but then I need to make sure it is connected at the other end. I each shock is on its own zone then I can put both shocks on one zone and the contact on the other, if not I will just add it in series to the shocks. If the cable has been delivered I will be having a play tonight Thanks Sohail
sullym6 Posted November 26, 2014 Author Posted November 26, 2014 I have take the cover off the shocks that used to be on the window that was removed, The shocks each have there own zone which is good the only issues is. the shocks are wired to trigger in the closed state and the contact is the other way round (closed when door closed and open when door opens) When I did some quick tests this would mean the alarm would trigger with the door closed. The cable being used is 8 core so I do have a spare pair but not sure if they are connect at the panel side, would an installer have connected these to the panel and just not programmed them? What is the easiest way to check if just need programming, I think I have a gardtec 595 Thanks Sohail
sullym6 Posted November 26, 2014 Author Posted November 26, 2014 I had a look at the 595 eng manual and there should be a review option but it is missing. Is there a quick way to tell it if it is a 595
Alarm Protection Posted November 26, 2014 Posted November 26, 2014 Tbh I would get a local company in now. !
sullym6 Posted November 26, 2014 Author Posted November 26, 2014 Hi alarm protection I think I will be fine with a little advice, I probably just need to get a contact that offers NC and NO option Thanks Sohail
al-yeti Posted November 27, 2014 Posted November 27, 2014 Don't understand what your saying, I thought shocks were already installed and you only wanted to add a door contact? If your not willing to mess with the panel but willing to mess with programming you may aswell Buzz through a pair and stick door contact on that Also you need to know what panel you have , "think" means guessing and any advice could be wrong To be honest programming can get confusing , get engineer? At least get a quote ?
