spbain Posted November 27, 2014 Posted November 27, 2014 i have installed a castle care alarm with digi-modem1200 and i was wanting it to send a text message when the alarm goes off.i have put sms message in format in program digi/sms settings but it does not send text message when alarm is activated.the mobile numbers are correct in settings. thanks
jiml Posted November 27, 2014 Posted November 27, 2014 do you get any errors like 'ARC call fail'? do you see the LED go active on the digi when sending a message?
jiml Posted November 27, 2014 Posted November 27, 2014 Sound like it is not enabled. First option in the ARC/SMS menu. Digi is Disabled/Enabled. Then for ARC1 which you have setup as SMS, it needs to be Active Yes. You need content type 6 to be on also btw. And do not remove the SMSC number.
