Can You Suggest A Wireless Alarm Please?
2020
Hello everyone,
I've been reading you fantastic site, and hope you can also help me,   I'm looking for a new alarm.....
Current Setup
I've just moved into a house with an old alarm.  From what I've been told my current alarm has two parts...
Wired - About 15 window sensors are wired through to a mains connected Gartec 800 alarm panel, the external bell is also connected back to here.
Wireless - 3 wireless PIRs, and a wireless keypad are connected through to a mains ADT Honeywell Dominial alarm. This in turn connects back to the Gartec, and also links to a phone line.
Requirements
Given the age of the setup I've decided to replace, I would like to install the new alarm myself but I do have an electrician on hand who will assist with any mains/external work. My requirements are as follows...
  • Wireless alarm
  • Support for 6 wireless PIRs,
  • Alarm will be used by 2 people
  • Don't have any pets
  • Require 1 front door connector
  • I would like IP connectivity and maybe later on GSM connectivity.
  • I don't think I would want a separate keypad on the wall as I understand this would have to be wired to the mains or back to the panel.  I want to have the least wires as possible.
Regarding day to day operation.
Entering the house - I take it once we enter the house we use some remote control to press a key to disarm.  As the control panel will be located upstairs it will be too far away to get to hence the need for a remote device.
Exiting the house - I'm assuming when we leave the house we will use the same remote control to arm.
That's it. hope I've covered it all....btw I'm assuming the existing Wireless PIRs that I have will not be able to connect to the new system.
So can you recommend a decent alarm fro me please.....and thanks in advance for any assistance , I look forward to your recommendations. :xmas:
You looking for a professional installed system?
If so id recommend the hkc hybrid 1070. You can have a wireless keypad, keyfobs or app control
Nope, going to install myself.....
Replace the Gardtec unit with a Honeywell Galaxy G2-12 with Ethernet IP module and an RF portal module.  You can then ditch the Domonial and reuse the Domonial PIR's and buy a door contact.  Wire the keypad next to the panel in a cupboard.
If the plan is to replace the existing system completely, my recomendation would be a Texecom Ricochet system. Using the Elite 12W panel with Smartkey control fobs, it will meet all your requirements, including the IP / GSM connectivity, although they do add a bit to the cost. You may find cheaper systems like Pyronix Enforcer, but Enforcer is not as pleasing on the eye or as user friendly in my opinion.
Thanks for this option - regarding the keypad if we install in the cupboard will we still have wireless keyfob access to enter/exit the house. Don't like the thought of running upstairs on entry to enter a code to turn off....
Thanks for this - yes I think I need to price this option up, but I agree it looks good and like the thought of "mesh wireless technology" O_O
Yes, when you add the C079 wireless portal, you can use two way wireless detectors along with RF set/partset/unset fobs.
My thoughts are that the Galaxy is probably your cheapest option, but if you have a large home, where reception may be difficult, then it may be worth spending the extra on the Mesh based wireless system.
GalaxyGuy will these fit my needs?
Option 1
Honeywell Galaxy 2-20 Wireless Starter Kit
http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=1632
£227
Kit Includes. 1 x Galaxy 2-20 Control Panel, 1 x Radio Portal RF Interface, 3 x Wireless PIR's, 1 x Wireless Door Contacts, 1 x LCD keyPROX Keypad.
Will I need anything else?
Option 2
Or is this a better fit?
Honeywell Galaxy G2-12 Panel & Proximity Keypad (£100)
Honewell Galaxy RF Wireless Portal C079-2 (£52)
Honeywell Domonial Wireless PIR (£37 x 3)
Honeywell Galaxy Door / Window Magnetic Contact White DO800M (£35)
(not sure if I also need a Honeywell Domonial LCD Radio Keypad c/w Built in Prox Reader)
Hi, am I on the right lines with....
Texecom Riccochet Premier 24W Live complete kit
£322
Texecom Ricochet Premier Elite Wireless Digital Quad PIR
£53  (will need 3 so £159)
total £481
