scantronic 9651
Guest neil.o sullivan
Hi lads I have just brought a 9651 I have managed to connect the keypad but the instrutions do not show where things like P.I.Rs door contacts and bell wire in very clearly any help would be great ie more clear diagrams more in laymans lanugue you can email me direct @ brenda.o@ntlworld.com
thanks neil.o
Youv`e choosen a good panel, and looking through the manual it appears fairly straight forward to me.
Typical Bellbox connections:
Hold+ = 12V Aux
Hold- = 0V Aux
Tamper Return = TR
Bell Trigger = OP1
Strobe Trigger = OP2
Strobe + = 12V Aux
Detectors:
Each detectors tamper circuit will be added in series to make a global tamper loop runing through all your detectors, and wired to the COM A/T terminals.
Each 2 detector zones will each share a terminal and use one per zone terminal. So 2 zones = 3 terminals:
Zone 1-Common-Zone 2,
Zone 3-Common-Zone 4,
Zone 5-Common-Zone 6,
Zone 7-Common-Zone 8.
Any detector can go on any zone as the panel is fully programmable.
All detectors will share the AUX supply if needed.
What sounder were you thinking about connecting.
Dave Oxendale
York based security systems engineer.
Hi when you say about the sounder what do you mean exactly this is the first time I have done this and are learning as I go along I had the system running to the point of of it constantly show up sounder tamper fault the pirs worked fine with the walk test I linked out the remainder of the unused zones etc the bell works fine thanks neil.o
Guest Guest_neil.o sullivan_*
Hi again lads would just like to thank everyone who gave out info this proved very useful as the system is now fully working.
