james.wilson Posted December 20, 2014 Posted December 20, 2014 This is program 1? Also if you do as you say and leave it to go off what circuit is indicated on disarm? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
timmo66 Posted December 20, 2014 Posted December 20, 2014 Does the door trigger immediately by any chance?
james.wilson Posted December 20, 2014 Posted December 20, 2014 Does the door trigger immediately by any chance? that was my track lol securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted December 20, 2014 Posted December 20, 2014 Evening Double-checked my program 1 setup and it's as I described in my OP - zone 1 = used\timed zone 2 = used\inhibited zones 3 to 8 - unused I performed a factory reset and reprogrammed, just to start from scratch again. efficient_systems - Looking at the Engineer's manual, the zone setup is the same for all 3 programs, the only thing that I have changed on program 1 is to set zones 3-8 as unused and left programs 2 and 3 unchanged, is this okay? Is there any else that can cause the pir to activate the entry timer when the entry route has not been activated? Could I have a duff panel......? GF So as the dodgy alarm blokes pointed out when you set the alarm, leave from front door what happens when you go back in through the door? They not really dodgy lol
gfarrel Posted December 22, 2014 Author Posted December 22, 2014 Hello Sorry for the late reply, been unwell. Anyway, if I re-enter through the door containing the door contact, the entry timer starts, enter code and alarm dis-armed (as expected). jameswilson - honest it is program 1. I will let the pir pick me up, allow the entry timer to expire and then I will check the panel. GF
al-yeti Posted December 22, 2014 Posted December 22, 2014 If it shows up James says have you got a leg crossed at panel ie done something weird in there?
efficient_systems Posted December 27, 2014 Posted December 27, 2014 Hi again, Sorry for the late reply, I need to set up notifications for replies! Before going any further, do a walk test to make sure these sensors are actually on separate zones, it sounds like they could be linked into the same zone. If it is setup as you said then the next thing to try is disconnecting the sensors and using a wire to short/open the zones to test manually, this will eliminate any wiring faults and confirm a panel fault (very rare on these). C
