Tcb800M-1 Panic Function Not Working
matt5595
Hi,
Just trying to use the panic function for the TCB800M-1 keyfob with the galaxy 2 after three seconds the LED's flash then nothing happens, I tried this while the system was unset!.
The keyfob will set, unset part set and night set, I also assigned it through the user option, and under the master user
Any advice would be great!
cheers
Have you enabled hot keys?
Its under 51-prams somehwere IIRC. Enable hotkeys and then function or PA and Set I think
just looking at the manual see it now 51.13, select mode as 2, and audible panic as 1
cheers lads
never new that can mimic fire, panic and assistance through the remote keypad, clever stuff
That's for keypad not the key fob
