Hi,
Just trying to use the panic function for the TCB800M-1 keyfob with the galaxy 2 after three seconds the LED's flash then nothing happens, I tried this while the system was unset!.
The keyfob will set, unset part set and night set, I also assigned it through the user option, and under the master user
Any advice would be great!
cheers
just looking at the manual see it now 51.13, select mode as 2, and audible panic as 1
cheers lads
never new that can mimic fire, panic and assistance through the remote keypad, clever stuff
Have you enabled hot keys?
Its under 51-prams somehwere IIRC. Enable hotkeys and then function or PA and Set I think
That's for keypad not the key fob
