matt5595 Posted January 8, 2015 Posted January 8, 2015 Hi, Just trying to use the panic function for the TCB800M-1 keyfob with the galaxy 2 after three seconds the LED's flash then nothing happens, I tried this while the system was unset!. The keyfob will set, unset part set and night set, I also assigned it through the user option, and under the master user Any advice would be great! Quote
al-yeti Posted January 8, 2015 Posted January 8, 2015 Pa set to silent? Enable bells for it Etc Quote
Lwillis Posted January 8, 2015 Posted January 8, 2015 Have you enabled hot keys? Its under 51-prams somehwere IIRC. Enable hotkeys and then function or PA and Set I think Quote
matt5595 Posted January 8, 2015 Author Posted January 8, 2015 just looking at the manual see it now 51.13, select mode as 2, and audible panic as 1 lads never new that can mimic fire, panic and assistance through the remote keypad, clever stuff Quote
al-yeti Posted January 8, 2015 Posted January 8, 2015 Have you enabled hot keys? Its under 51-prams somehwere IIRC. Enable hotkeys and then function or PA and Set I think That's for keypad not the key fob Quote
