Percha Posted January 16, 2015 Posted January 16, 2015 Hi, First of all hello! I have a regent alarm panel and scantronic 9427. I want to replace panel and keypad. I have 5 pir's two door contacts, also two door contacts in garage and another key pad in the garage. What panel and keypads do you suggest? I was think accenta g4 metal case one? Can anyone suggest a good panel and keypad that is reliable and I could diy fit? Also I am thinking about the dialler option which I can see if you add the informa will do on the accenta.
norman Posted January 16, 2015 Posted January 16, 2015 Thought they just did cars and vans? Nothing is foolproof to a sufficiently talented fool.
al-yeti Posted January 17, 2015 Posted January 17, 2015 Thought they just did cars and vans? Your so funny sensei , how come you don't have your own section? Lol still your funny
norman Posted January 17, 2015 Posted January 17, 2015 I do, invite only though. Nothing is foolproof to a sufficiently talented fool.
Percha Posted January 17, 2015 Author Posted January 17, 2015 Well I would like to keep it around £100. Then add later comma to ring or text me. I hope I can leave pir's and door sensors. Replacing panic alarms as they look very old.
al-yeti Posted January 17, 2015 Posted January 17, 2015 Accenta would do then, with LCD keypad, better to have new battery http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=864 Squeeze another £20-30 and get a dialler to Panics are cheap http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&cPath=36_46&products_id=2542
Percha Posted January 17, 2015 Author Posted January 17, 2015 Great thanks for the links, yes I think new battery and new bellbox (real and dummy)
Percha Posted January 17, 2015 Author Posted January 17, 2015 One question why would you choose a metal over a plastic other than a bit more rigid setup. I was thinking this one:http://www.tlc-direct.co.uk/Products/TSACG4M.html
