Recommend Me A Wireless System.
jonny_bravo
I was thinking about the DIY approach if possible.
The Scanny I On is a good panel but I'm sure only 1 way wireless. You should go 2 way wireless so I would recommend the Pyronix Enforcer panel.
I would also suggest that you obtain 3 quotes from registered companies.
We have started to use the Risco equipment too. We have had a few issues with the door contacts going faulty. Except for the door contacts everything seems to be good quality.
I'm a big fan of Risco and have used them for the past 12 years. Is it the 2 way contacts or 1 way?
We have had a few issues with the Grade 2, 2 way contacts.
Thanks for the comments chaps, taking it all onboard. What are your feelings on the wireless coverage ? Am I asking too much for it to reach the garage? (Probably of no significance , but I can get on my WLAN from the garage)
Texecom ricochet might be better then? Or a galaxy g2 with the wireless card mounted close as possible to garage
Or any panel with repeater solution
Ok can't resist , proffessionaly installed hkc panel with repeater ? I hear there sensors can be weather proof!
Approx 15m from the house, I could situate the control unit so it only had one exterior wall to penetrate.
Galaxy wireless would be okay at that distance. Got a site which about 15m though 2 stone walls and across a courtyard.
The enforcer is a nice little domestic type panel, 2way wireless, keyfobs can be reprogrammed and it can be linked to an ARC or send SMS.
As others I'd reccomend getting quotes for repetuable local company's.
See SSAIB or NSI.
If going for wireless you need to look at full system with 2 way wireless.
Keep in mind some manufacturers have 2 way and 1 way in the same kit.
What is your budget?
You should consider having an approved company install a system for you, unless you are set on DIY.
