Guest nigelbt Posted February 25, 2003 Posted February 25, 2003 Hi again Dave, another question, i have installed resistor on keypad and all other things are ok, problem is when i power up keypad makes a continual chirping noise and display is on but only blocks displayed across whole of screen, can you advise me please,thanks ,Nigel.
Service Engineer Posted February 25, 2003 Posted February 25, 2003 Check the A and B wires are correctly wired at the panel and keypad. Check the Keypad Selector switch is set at "0" or possibly "1" The 680 ohm resistor should be accross the A and B terminals. Follow these instructions to do a keypad self_test. ........................................................ Dave Partridge (Romec Service Engineer)
Guest nigelbt Posted February 25, 2003 Posted February 25, 2003 Thanks Dave, all connections are ok, i have tried to do a self test but no change, only thing i did notice was power - termination came out whilst i was fiddling and display still flashed showing mk v11 keypad, v.3.00 and whan i let go of the ent key it showed "alarm active" flashing (not sure if this has any relevance as only + connected, i have made sure all other connections and lids are secure but still same problem, i cant even get an option up to try any codes, Nigel.
Service Engineer Posted February 26, 2003 Posted February 26, 2003 The Alarm Active display was the panels way of asking you to enter either a User or Engineers code, so at the point mentioned earlier in your message a code should have been entered. Also check the selector switch at the rear of the Keypad, try powering up with the selector set at 0 and if that doesnt work try setting the selector to 1. ........................................................ Dave Partridge (Romec Service Engineer)
Guest nigelbt Posted February 27, 2003 Posted February 27, 2003 Hi again Dave i am just posting this message to thank you for your help, i rang galaxy helpdesk today and have tried a number of things including resetting all codes but could not get it to work, the gent on galaxy has told me it looks like the panel is shot, i am trying to get another panel now and will post some more questions if thats ok if i get stuck with that one, thanks again, Nigel.
Service Engineer Posted February 27, 2003 Posted February 27, 2003 Ok nigel, sorry things didnt work out for you, your welcome here anytime so if you get stuck just post a message. ........................................................ Dave Partridge (Romec Service Engineer)
