Advice About Protecting The Control Panel?
Hi,
I have been reading some of the excellent advice on the forum and have decided to try and DIY install a wired Texecom Premier Elite 24 panel in my ground floor flat. (It will be bells only, as there are always other neighbours in the building.)
There is an obvious place to site the panel in a cupboard my hallway. However, I have read about "smash and grab" attacks that can disable the panel before the entry timer has finished. So I have two questions:
1) If someone kicked in the door and reached the panel before the entry timer finished, could they prevent the siren from triggering? Or would pulling it from the wall or destroying the panel somehow trigger a failsafe in the external sounder (which will be wired)?
2) Would it be a possible to put a PIR in the cupboard with the panel, that will trigger an immediate alarm if someone enters the cupboard even during the entry countdown? (I would put the keypad in the hall for this setup.)
Thanks for any advice.
  • Replies 21
  • Views 4k
  • Created
  • Last Reply
The attacks you mention are more common in smaller spaces (where the panel is obvious or easily found) or planned jobs, and to be honest they are the reason a professional would (or should) always at least offer monitoring, of a type whereby the connection itself is constantly checked - 'monitored monitoring' if you like.
However, you are right that a correctly installed bell will have it's own battery to protect against such an attack. But, will it be external or next to the panel, i.e in the hallway?
I can see that such an attack could prevent the panel from alerting a monitoring company. But from what you say, an attempt to destroy or disconnect the control panel should trigger a correctly installed bell (which I am mounting externally).
That's great, as it will simplify my setup, and mean that I can put a cheaper keypad in the cupboard with the panel (rather than a designer one that is to be "on display").
My flat is not huge, and I am just trying to protect against petty thieves, as I doubt anyone more serious would find much to justify their efforts.
The downside to the keypad in the cupboard is;
You will not be able to protect the panel during entry/exit (if it's in the same cupboard)
It will highlight to an intruder where the panel is
Also, just talking from a professional POV, the contents of a premises are part of a risk assessment, but not everything. I'd
personally only ever install to a minimum standard if a flat had £2 or £20000 worth of valuables.
Having an outside bell is definitely a good move though if you are relying on bells only, as it will greatly reduce the opportunity
to destroy both the panel and bell simultaneously.
You mean an intruder will be alerted to its location by the keypad beeping during the entry countdown? I hadn't considered that.
Based on what you have advised, I think I will have the following approach...
- Keypad in hallway
- Panel in cupboard
- Cupboard door protected by magnetic contacts (which I hope can trigger an immediate alarm condition, even during entry?)
Many thanks for the advice.
Ha ha! Very true.
I'll have an internal sounder which should therefore trigger, and be loud enough to alert the other households in the building.
Ok. Set of ur internal see how many come to ur aid?
I guess you are saying any bells only setup is weak security? If so, I concede your point.
But I just want my alarm to do two things .. 1) deter thieves and 2) make a noise if someone tries to break in.
There are other households in the building who I trust to investigate or call me if they hear the alarm.
