Risco Prosys 40 Will Not Except Gmc Or Installer Code
m300raj
hi I did a general service of my alarm this and replace the CP battery as it was getting on to 4 years old as a precaution after which the system rebooted but would not except GMC I then thought it may have defaulted but that did not work either I can enter the engineer menu either option 7 as the engineer code will not be accepted it just bleeps after code entry and goes back to menu.
Any help appreciated
Raj
Hi yes I did install the system so I have all the codes it just will not let me in when I go to menu 7 engineer/advanced I previously had no problems getting into the system to make changes like adjusting system time.
Just all a bit strange
Ok I think I found the problem but need help
I need a anti code to reset the system
Can anyone help Me with a copy of the software
