Risco Prosys 40 Will Not Except Gmc Or Installer Code
m300raj
Maybe it's wrong code and you locked yourself out? I wonder does engineers access need to be granted before trying to access all menus I don't really know this panel
The problem is that you don't really know what your doing and trying lots of things hoping they work only introduces further issues that because your not familiar with the system. I would be inclined to wipe everything and start again.
This system took a while to program to work just right I don't fancy doing it all again for the sake of a simple anti code. I wish I had downloaded the software when I had access to risco site. I will pursue tying to find someone willing to help in the meantime I have CCTV which I can access remotely to keep an eye on the place.
Anticode? Set by you on original installer ? It's set for anticode so user can't reset it , hence why you can't get into engineer mode either because perhaps code is incorrect
Sorry bit strange really, it's straight forward to programme
Exit terminator ie what ever is used for exit setting perhaps
Why do you think it's a fault code? P1 could just be partion 1
Your trying to guess your way round the panel and your questions will be endless if you installed it you must have the manual its all in there hope it works out or get an installer to sort it for you
