Not sure I understand the question
Possibly as above the relaybhas been programmed to do something under certain conditions or something , if that's possible check what the relay is set to do
Im only running with 2 detectors on a small run of cable, i will swap the detectors over with some spares I have
From what I can gather the Gent nano panel is very cut down from the stuff you guys probably deal with and as such quite straight forward menus, but i will look again and see if I can see anything thats responsible for this clicking
I might also try the loop with no detectors at all in the bases and see if it still clicks
Are you shure the loop is ok and its not the panels loop isolators operating.
If you have it on a bench and the loop is made up of a couple of meters of cable, the loop may be to short and resistance of the loop is not enough for the panel.
www.nova-security.co.uk
www.nsiapproved.co.uk
