Squidger Posted February 15, 2015 Posted February 15, 2015 Hi all, We have a Risco Lightsys alarm fitted and control it through an Android App via Risco Cloud. We wanted to swap out our router for a new Belkin one with more features for our business but Risco Cloud isn't liking it and I get a 'panel not connected' fault. I have changed the IP setting on the Lightsys panel so it can see the new router but it still doesn't want to connect to the cloud. Would anything need to be changed on the router or is there something I'm missing in the Lightsys menus? Any guidance anyone can give on this would be much appreciated. I thought it would be a fairly simple swap but maybe not Quote
PeterJames Posted February 15, 2015 Posted February 15, 2015 Did the ip range change? for example 192.168.2.1 to 192.168.0.1 if so the panel probably needs the power recycling as the panel is still trying to connect to the old ip. If the ip range is the same then my advise would be call your installer you should probably do this anyway Quote
Lwillis Posted February 15, 2015 Posted February 15, 2015 Is the new router blocking any ports? Quote
PeterJames Posted February 15, 2015 Posted February 15, 2015 Is the new router blocking any ports? Its a belkin so probably all ports are open Quote
Squidger Posted February 15, 2015 Author Posted February 15, 2015 Is the new router blocking any ports? Not that I know of but I'll check in the morning and will also recycle the alarm power to see if it accepts the new IP that way. Thanks for the input so far guys. Quote
james.wilson Posted February 15, 2015 Posted February 15, 2015 the risco cloud could be down. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Lwillis Posted February 15, 2015 Posted February 15, 2015 the risco cloud could be down. Don't think its the cloud, we've got a agility on test in the office and it seems to be connecting to that okay. Try resetting the network settings on the panel. Can you ping it over the local network? not sure what ports the lightsys uses but IIRC the agility was fairly high Quote
james.wilson Posted February 15, 2015 Posted February 15, 2015 You cant say its been reliable. Long term it will be like tap sms. You dont get reliable for free. #justsaying Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
m300raj Posted February 16, 2015 Posted February 16, 2015 I would say you first need to reboot the router first Does the the router see the pannel? Is the router using a static ip for the pannel or is it DHCP? Quote
secureiam Posted February 16, 2015 Posted February 16, 2015 not had any issues with the risco cloud for a while now, whoops shouldn't have said that. Quote
