mweetman Posted February 16, 2015 Share Posted February 16, 2015 Hi I have a Scantronic 9100 that has been serviced by a local firm since I moved into my house 14 years ago. The alarm was working fine untill it was last "serviced", but the engineer said that the panel was now broken & needed replacing. I was suspicious of this as the panel was working fine before he arrived. Anyway, I was involved with Scantronic on the design on this panel, so I took a look at it. The unit is stuck in programming mode. I can perform all the programming functions, including walk through & bell tests. However, when I try to exit programming mode with "99 Enter", i get a low beep & "-" is displayed. Hence the unit appears to be stuck in programming mode. As the unit is wired to the line, I don't want to open it up till I understand what is going on. Any hints as to why "99 Enter" wouldn't work? Thanks.... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/ Share on other sites More sharing options...
MrHappy Posted February 16, 2015 Share Posted February 16, 2015 Tamper(s) or the 20+ yrs old product is knacked Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/#findComment-410967 Share on other sites More sharing options...
abbz Posted February 16, 2015 Share Posted February 16, 2015 The lid spring on pcb needs stretching a bit as not making proper contact with lid. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/#findComment-410971 Share on other sites More sharing options...
Nova-Security Posted February 16, 2015 Share Posted February 16, 2015 As above or the battery which can cause strange faults on these. We still have some of these going and still have a replacement PCB www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/#findComment-410972 Share on other sites More sharing options...
andy82 Posted February 16, 2015 Share Posted February 16, 2015 As above there is an open tamper somewhere try holding the tamper switch down with your finger then exit engineer mode, from past experience the lid tamper can be a bit temperamental on those Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/#findComment-410974 Share on other sites More sharing options...
mweetman Posted February 16, 2015 Author Share Posted February 16, 2015 Thanks for all the great help! Sorry for the dumb question, but in this state, will the unit dial out if I open it up? I guess not, but thought I would ask. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/#findComment-410975 Share on other sites More sharing options...
PeterJames Posted February 16, 2015 Share Posted February 16, 2015 Thanks for all the great help! Sorry for the dumb question, but in this state, will the unit dial out if I open it up? I guess not, but thought I would ask. Its still in engineer so wont do anything Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/#findComment-410977 Share on other sites More sharing options...
james.wilson Posted February 16, 2015 Share Posted February 16, 2015 But id speak to your maintainer first. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/#findComment-410979 Share on other sites More sharing options...
Hillbilly Posted February 16, 2015 Share Posted February 16, 2015 Power reset after battery change? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/#findComment-410985 Share on other sites More sharing options...
mweetman Posted February 16, 2015 Author Share Posted February 16, 2015 The tamper switch was to blame. Thanks so much to everyone. Martin Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38114-9100-wont-exit-programming-mode/#findComment-410988 Share on other sites More sharing options...
