timmo66 Posted February 21, 2015 Posted February 21, 2015 No, you'd be surprised how easy it is to forget about the masterblaster...
ibruceuk Posted February 21, 2015 Author Posted February 21, 2015 No, you'd be surprised how easy it is to forget about the masterblaster... Maybe move the Smoke Cloak from the garage to the house then
Nova-Security Posted February 21, 2015 Posted February 21, 2015 Have you got smartwater in the silver cupboard ? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
ibruceuk Posted February 21, 2015 Author Posted February 21, 2015 No, not yet! lol I enjoy tinkering and yes I totally agree that a Galaxy 520 in a domestic is way OTT as is a smoke cloak in the garage/workshop/office but it's good fun I do have another query if anyone fances a stab in the dark with it I am getting a message on the normal Mk7 rkp when setting which says "2 RF TO CHECK" and when I scroll through them it is the two smoke detectors that are listed. On checking them they are both showing 10/10 for signal strength so I'm confused about what it wants me to 'check' exactly!
al-yeti Posted February 21, 2015 Posted February 21, 2015 Rf check , supervision loss? Perhaps battery low? Is there anything else in the log? (Detailed) What receiver are you using out of curiosity?
al-yeti Posted February 21, 2015 Posted February 21, 2015 Just thought if not that does it ask you to view?
ibruceuk Posted February 22, 2015 Author Posted February 22, 2015 Typical! I just tried to replicate it so I can grab screenshots from the Online keypad and lo and behold it doesn't do it! There's nothing in the logs at all which is strange. I'll try and describe it from memory. When trying to set the rkp says "2 RF TO CHECK Press ENT or < > to view" or something similar. Pressing Ent begins setting pressing < or > cycles through 2 zones... 1051 Smoke Up FIRE and 1052 Smoke Down FIRE When it happens again I'll grab some screenshots. Thanks, Ian EDIT : Forgot to add - it is an RF Portal (C079-2)
al-yeti Posted February 22, 2015 Posted February 22, 2015 Then you might have some zones set to precheck
timmo66 Posted February 22, 2015 Posted February 22, 2015 Has it always done this or just started recently?
Nova-Security Posted February 22, 2015 Posted February 22, 2015 Burnt the toast needs manager code to reset Check reset levels www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
