johnjoeedgar Posted February 23, 2015 Share Posted February 23, 2015 (edited) Hoping someone can help me out I've just got a gardtec 500 panel from one of my mates who has removed it from an empty property he is refurbing,as I didn't need anything special it is only for my garage, but after powering it up the code PC is in the display don't know what it means hope someone can help I also noticed that in this mode if I tamper it will trigger the speaker and the code #REMOVED# doesn't work can anyone shed any light please Edited February 24, 2015 by sixwheeledbeast No codes, please Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 23, 2015 Share Posted February 23, 2015 its from an old maintained system. Its secured so of little use. Plus with its age and little panels now have more options id give up on it Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
johnjoeedgar Posted February 23, 2015 Author Share Posted February 23, 2015 Hi James by secured do you mean I can't reset the panel I only need it to work a couple of pir,s I have an old gardtec 300 in my house that's been going strong for the past 17 yyears and have the engineers manual somewhere but can't find it at the minute was hoping this might be the same and maybe get me up and running with the engineers codes Quote Link to comment Share on other sites More sharing options...
9651 Posted February 23, 2015 Share Posted February 23, 2015 it locked,as in you cant default it back to factory parameters. Seriously you'd be better with a eurosec Quote Link to comment Share on other sites More sharing options...
fertilebert Posted February 23, 2015 Share Posted February 23, 2015 (edited) PC means no 240 v And #REMOVED# is the default user code , you could get an engineer to crash it and reprogramme , don't think any one on here will give you instructions how to do this however coz its trade only information. Edited February 24, 2015 by sixwheeledbeast Quote Link to comment Share on other sites More sharing options...
fertilebert Posted February 23, 2015 Share Posted February 23, 2015 Like the other members have said , is it worth the hassle , you could just go and buy yourself a Texecom veritas or similar for next to nowt. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 23, 2015 Share Posted February 23, 2015 as above its very old Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Lwillis Posted February 23, 2015 Share Posted February 23, 2015 As above, they can be locked. Bin it and fit something more up to date. Veritas or Euro Mini Quote Link to comment Share on other sites More sharing options...
johnjoeedgar Posted February 24, 2015 Author Share Posted February 24, 2015 thanks guys for the replies the comment from fertilebert is interesting as ive only powered it up with the battery to see if there was any resoponse from the panel if i connect it to the mains will this make a difference to the codes being put in ?? im not giving up yet this might be the solution to my problem im not bothered if i end up binning it but would like to give it another try Quote Link to comment Share on other sites More sharing options...
fertilebert Posted February 24, 2015 Share Posted February 24, 2015 (edited) Wont make any diiference code wise, like I said #REMOVED# is the default user code , which has obviously been changed , If your lucky the engineer code will still be the default and you will be able to reprogramme it .Your eng manual for your other Gardtec panel is the same by the way if you can find it , otherwise you will probrably find a manual on line . Edited February 24, 2015 by sixwheeledbeast Quote Link to comment Share on other sites More sharing options...
