al-yeti Posted February 25, 2015 Posted February 25, 2015 Virgin probably installed it from where there t was situated , if you cause a fuss they will probably come out and install it cheaper , otherwise you pay full for an extension whatever there charge is Quote
Adi Posted February 25, 2015 Posted February 25, 2015 You can't use a wireless extender as the phone line is monitored, the extender might be able to provide 50v at the panel, but what if the actual telephone line goes down??, it won't be monitored. Virgin and bt will always put the master socket where it is easiest for them. There all tw@ts, just like sky and all the others. At first, i agreed with norman, but then also not sure why they want to puta new 'box' in and charge 1000. They could run a new cable to the master socket and bill you for that. Might be a case of having your pants down. Telecoms chap is probably the way to go, although i'd of fooked off the virgin engineer andtold them were to shove it. Quote I really can't be ar**** with it anymore.
PeterJames Posted February 25, 2015 Posted February 25, 2015 Why? I have nothing against ADT, however, a local would just quote a GSM or Wifi solution for a lot less than £800, now ADT may also be a lot less than £800 but engineer should have called the office and quoted the correct price. At the end of the day its about giving the customer the right information so they can make the right decision Quote
goncall Posted February 25, 2015 Posted February 25, 2015 I have nothing against ADT, however, a local would just quote a GSM or Wifi solution for a lot less than £800, now ADT may also be a lot less than £800 but engineer should have called the office and quoted the correct price. At the end of the day its about giving the customer the right information so they can make the right decision the way i read it is the adt engineer didnt try to get him to upgrade and gave the cost reason as to much to be viable and probably told the sub to get a socket fitted next to the panel,but then you have 2 members encouraging the sub to ditch adt for no reason than they are not a local,now thats what i call impartial advice Quote
james.wilson Posted February 25, 2015 Posted February 25, 2015 I think the best advice is to get a bt/virgin socket fitted so the op can continue with his service provider. re impartial, they would say that wouldnt they Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
goncall Posted February 25, 2015 Posted February 25, 2015 I think the best advice is to get a bt/virgin socket fitted so the op can continue with his service provider. i think its the normal answer most would give Quote
datadiffusion Posted February 26, 2015 Posted February 26, 2015 the way i read it is the adt engineer didnt try to get him to upgrade and gave the cost reason as to much to be viable and probably told the sub to get a socket fitted next to the panel,but then you have 2 members encouraging the sub to ditch adt for no reason than they are not a local,now thats what i call impartial advice No, it sounded to me as if ADT had already given their options / reasons to the OP and he didn't like either of them. They also stated that to wire a socket would be very difficult if not impossible. So GPRS would have been a good solution. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
norman Posted February 26, 2015 Posted February 26, 2015 But the most cost effective would be a socket in the kitchen. Quote Nothing is foolproof to a sufficiently talented fool.
Chall Posted February 26, 2015 Author Posted February 26, 2015 No, it sounded to me as if ADT had already given their options / reasons to the OP and he didn't like either of them. They also stated that to wire a socket would be very difficult if not impossible. So GPRS would have been a good solution. Not that I didn't like either of them I'm quite happy to get another extension but I didn't see why the wireless extender wouldn't have worked. But I have learnt that GPRS is probably the way to go and we will look into that in the near future. Thanks for all the responses, you've been most helpful. Quote
datadiffusion Posted February 26, 2015 Posted February 26, 2015 (edited) But the most cost effective would be a socket in the kitchen. You're saying that, but £kitchen socket + £reconnection + £carrying on with existing monitoring = £? Vs. takeover and digiair = £? Could be drastically different over the long run. If ADT had offered a GPRS solution, I wouldn't have taken any issue with that, at all. I am NOT anti ADT (or any national) OP, the reasons the wireless extender is no good (and this may differ to how you understood it / how it was explained) is.. 1. It may not support the kinds of data the alarm transmits due to very tight bandwidth / clipping 2. It may or may not provide 50V when the 'telephone' (alarm modem) is perceived to be 'on hook'. 3. If the above is wrong, in that case it would almost certainly still provide 50V even when there is no outside line, so the alarm would not know the line had been cut / failed. 4. If the power were to fail (or, more importantly, be turned off deliberately) your alarm would not communicate, at all. Edited February 26, 2015 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
