Accord Xpc
  • Replies 27
  • Views 4k
  • Created
  • Last Reply
I have a double doors at the back where I would like to wire double door contacts. Currently I have one pir in the living room and I would like to wire second because of the length of the room and the RSJ in the middle of the room.
Currently have following zone setup
Z1 front door contact
Z2 back door contact. Now double doors
Z3 kitchen pir
Z4 living room pir now extended
Z5 passage pir
Z6 bedroom 1 pir
Z7 bedroom 2 pir
Z8 panic button
I would like to double up zone 2 and 4
Edited by Vick
In reality the panic button would be unlikely to be used ime, is it a bungalow?
Also let us see a floor plan showing doors and windows please.
It's not a bungalow living room is 10.5 meters long
Edited by Vick
One should cover that, may have to replace it if it's an old 'en though.
Assuming no real obstructions to the room.
There is obstruction on middle of the room where the current extension is being built. It has RSJ and two side walls entrance to the extension is open. Does not have a door in middle. Pir does not trigger until coming to middle of the room
OK then, the 2 bedrooms, are they on the 1st floor and if so any flat roofs or other means of access? Are there any safes valuables in them?
Two bedrooms are on the first Floor. Extension has a pitch single storey roof. Just connect below the first floor bedroom windows
Makes more sense now now , does the manual show on how to wire up contacts in series
How does the door operate , overlapped or independently?
model of pir in room? Perhaps reposition it , replace it with a longer range pir ?
