JohnCo Posted March 16, 2015 Share Posted March 16, 2015 Hi folks, Sorry if this has been covered before, I have looked but I couldn't see exactly my situation .. please point me to the correct place if you know it. OK.. here's my problem. I have got hold of an alarm system and bell box which will be installed in my garage with just 2 or 3 PIR's. I just need to clear up the connections between the two units as they seem to use different terminology so to an amateur it gets confusing what's actually going to work. The connections on the Bell box are as follows Tamp out Tamp In Micro /S Supply - Supply + Trigger Strobe + Strobe - And on the 9448+ I have Clk Data O/P L/S + TR 0v 12v BELL STR I have tried to follow the 9448 install diagrams but it uses different terminology and i'm clearly not getting it right. SO what would I connect each of the Bell connections to on the 9448+ unit. Help please !! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38265-9448-flash-guard-bell-connections-help/ Share on other sites More sharing options...
datadiffusion Posted March 16, 2015 Share Posted March 16, 2015 Tamp out - TR Tamp In - connect locally to Supply - (0V) Micro /S - god knows Supply - - 0V Supply +- 12V Trigger - BELL Strobe + - ASSUME connect locally to Supply + (12V) Strobe - - STR Please note I don't know the Flashguard at all, but the terminology seems pretty normal, except for the Micro /S? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38265-9448-flash-guard-bell-connections-help/#findComment-413277 Share on other sites More sharing options...
JohnCo Posted March 17, 2015 Author Share Posted March 17, 2015 Nice one, thanks for the help ... it'll take a few days before I can get to try it so thanks in advance Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38265-9448-flash-guard-bell-connections-help/#findComment-413316 Share on other sites More sharing options...
datadiffusion Posted March 17, 2015 Share Posted March 17, 2015 Hold up, DO NOT do this >>> Strobe + - ASSUME connect locally to Supply + (12V) Connect NOTHING to Strobe + It doesn't need anything. Also is there more than one Micro S terminal?? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38265-9448-flash-guard-bell-connections-help/#findComment-413427 Share on other sites More sharing options...
JohnCo Posted March 18, 2015 Author Share Posted March 18, 2015 Got it , thanks There is only the one Micro /S connection Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38265-9448-flash-guard-bell-connections-help/#findComment-413436 Share on other sites More sharing options...
datadiffusion Posted March 18, 2015 Share Posted March 18, 2015 Ok, v. odd, good luck. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38265-9448-flash-guard-bell-connections-help/#findComment-413440 Share on other sites More sharing options...
