Accenta 8 Mini Problems
fibzy
thanks will check voltages at sensors and on the panel in morning and report back as im not really sure what readings  im looking for  :)
would google & alarm installer "your area" be some much easier ?
i imagine it would be easier yeah, and cost  a fair bit of cash i dont have.
tested the voltage at the sensors and its jumping arounbd all over the place,whats the next port of call???
checked voltage at board at all places i can see... pic attached 3 showing a solid 13.5 volts ish the other is jumping about between 7& 8 same as at the sensors
post-6868-0-83668400-1426958477_thumb.jp
Is that the ones giving out the wonky voltage?
heres a pic of the board wiring from the manual you think theyre in wrong place??
post-6868-0-12217500-1426960516_thumb.jp
