james.wilson Posted March 24, 2015 Posted March 24, 2015 an error where? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
eaglecomputersuk Posted March 24, 2015 Author Posted March 24, 2015 ON the lcd panel, as soon i connect the power it triggers the alarm, as a alarm
james.wilson Posted March 24, 2015 Posted March 24, 2015 In that case something basic is wrong. Its not the additional outputs of the bell. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
eaglecomputersuk Posted March 24, 2015 Author Posted March 24, 2015 Can you see the diagram i added with this post? hopefully that gives you a better understanding... I want to remove the aux/fault and wire it as a grade 2, or perhaps if anyone knows where to change the setting on the control panel (Keypad) so it doesnt read the aux/fault as default. Thanks
james.wilson Posted March 24, 2015 Posted March 24, 2015 You have to enable the other inputs if wired. Do you have a sabt issue rather than what your assuming? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
eaglecomputersuk Posted March 24, 2015 Author Posted March 24, 2015 but with the diagram is aboved, is working just fine with the 7 cores, bell works well when alarm is trigger without any faults
james.wilson Posted March 24, 2015 Posted March 24, 2015 Have you called tech support securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted March 24, 2015 Posted March 24, 2015 but if i dont connect anything on aux /fault i get a fault error... Did you programme it as fault or is already programmed
eaglecomputersuk Posted March 25, 2015 Author Posted March 25, 2015 its already programmed as fault...
al-yeti Posted March 25, 2015 Posted March 25, 2015 but if you don't need it and use it as grade 2 why do you need it as fault?
