You can reset the user code with the user number.
We cannot give out engineer manuals on this site.
I still dont understand why you need one? and whats an nvr anyway?
Well, I would have hoped that a professional installer had an idea what nvr was reqgarding a panel. I'm more used to fire panels having worked for Gent in the past. You dont seem to comprehend my message, I am quite aware how to change a user code! I need to reprogram the panel as its been set up by a installation cowboy, seem to be a few about from what I've heard so far.
I guess the users of this site just dont have an SL Compact engineer manual.
I think you may be referring to the 'NVM'?
Engineering information (including manuals) is only available to trade members of this site.
If you are not in the trade I would recommend you get a professional installer to service and reprogram your system fo you.
If you don't know......ask.
Yeah your right NVM = Non Volatile Memory also known as NVR = Non Volatile RAM, tis all the same thing!
I am not a "professional" alarm installer, but I am a professional Electrical Engineer having designed the sort of systems you guys are installing! Hence I always fitted my own!
Still I understand your concerns no matter how inappropriate they are.
  • 2 months later...
I HAVE EXACTLY THE SAME PROBLEM. I MOVED INTO THIS HOUSE AND WAS GIVEN THE ALARM NUMBER BUT THE PREVIOUS OWNERS ALSO KNOW THE NUMBER. I CAN SET THE ALARM BUT I WANT TO BE ABLE TO CHANGE THE NUMBER FOR SECURITY PURPOSES. DOES ANYONE KNOW HOW TO DO IT??
Guest Peter James
Hi Lab
If you know the current user code we can tell you how to change it, if you dont then you need to call the installer who can default it for you.
Its a good idea to get it serviced anyway.
Pete
Hi Lab
Pete
THANKS FOR THE ADVICE, I'VE FOUND A USER MANUAL ONLINE SO I'VE CHANGED THE CODE FOR NOW AND I WILL GET IT SERVICED AS SOON AS POSS.
  • 14 years later...
On 25/01/2004 at 23:07, Guest jiveturkey said:
HELLO DID YOU GET A MANUAL FOR YOUR SL COMPACT ALARM, PLEASE CAN YOU HELP ME I NEED TO RESET THE PANEL AFTER A TAMPER I CUT THHROUGH A WIRE WHEN I WAS DOING SOME FLOORING I RE CONNECTED THE CABLE AND THERE IS A TAMPER ON THE PANEL AND I CANT USE IT I KNOW THE SECURITY CODE AS IT IS MY HOUSE PLEASE CAN YOU CALL ME ON [EDITED] OR E MAIL ME : [EDITED] THANK
AKAY
Did you get a manual for the SL compact? I need to get hold of one to try to reset an alarm as we’ve moved into a new house and haven’t a clue of the code!
  • Downvote 2
You think after 16years he has hopefully binned the alarm altogether.....
Not sure if you will get a reply
  • Upvote 2
If you dont know the code then the user manual wont be much help, take a look at the bell box to see if thee is an installers name on it, give them a call and they will default the code for you for a small charge
  • Upvote 1
  • Downvote 1
Hopefully they still in busines to....
Doubt charge will be small tho , it's a matter of what you think is small ?
This topic is now closed to further replies.
