Keeping A 7Ah Charged Via 12V In Vehicle
Rulland
Seeing!, the lights in the backs of vans are ****, as we know.
I have a self adhesive 1m led strip scotchlok'd into interior light in the load space, works great
You fitting neons under your van? Wide boy eh?
 Thats what im doing, leds use **** all power.
have old old shape berlingos,
the led light is very bright & stuck on the metal over the barn doors & light the load space nicely,
factory 3.5mm type jack plug is on the led light & I used a 3.5 jack type socket with + & - scotchlok onto existing Citroen light
open the door led & Citroen light come on, both lights are controlled by  switch on the Citroen light, both lights dim as they time out....
there is 4 wires on the citreons 2 x neg & perm+ & lighting pos
lol Norm.
Any thoughts on this little thingamy jiggy? eBay-110728743531
Off the fag incinerator to my 7aH, I also got some bigger 'ens to if better.
Swb ciggy socket dies with the ignition, purely led strip-5 mtrs- to go around the inside of the back.
The internal light at the back times out even if overidden on the switch.
Nissan Primastar mate.
Yes, so after 15 minutes of the door being open the interior light will timeout
Ok so I would avoid the recharging an SLA option personally, it's possible a few ways but there are better ways.
Depending on the current of your LED strip you could use the permanent voltage at the rear door light to replace the bulb.
The rear light unit AFAIK will have a permanent and switched feed as the rocker switch can be switched to on, unless it's different from the Traffic's I have played with.
If you use scotchlock connectors (not keen on them but they are best here) they could be removed in the future easily.
Failing that you may find an AUX voltage feed under the centre console or the radio will have a permanent supply, again these are all down to how much current the LED's are.
Alternatively there's solar, a small solar charger with some croc clips should be easy to rig up.
If you really want to go down the ciggy socket route and you are good with a soldering iron I would bash this together.
http://ludens.cl/Electron/12Vcharger/12Vcharger.html
Or you could buy an off the shelf 12v solar charge regulator or caravan split charger system.
They are two different things and wired differently but would do the job, either easily picked up from Maplin's, CPC or online.
I would consider this a PITA messy solution as the socket is used and wiring will be a pain.
What a messy job! Crimp the resistors aswell as solder, come on you alarm technicians all easy stuff circuit building?
You will need quals to build that I reckon
