Hi not sure if you have already looked at any install manuals for detectors but I've done a few with pet immunity and anywhere where pets can get up at a certain height can cause false alarms so be careful.  just as an example I've attached a link to a Honeywell activ8 pet immune detector.  I would at least mount it so it won't point towards anywhere that allows the dogs to be in a closer range to the detector, but if you also think about it a bunch of dogs could maybe pass as something larger that could trigger a false alarm?
https://www.tlc-direct.co.uk/Technical/DataSheets/Ade/TSACTIV8DT_Instructions.pdf
I'd recommend the siemens pir. Tested with a single large lab with np false alarms so far
https://www.securitywarehouse.co.uk/catalog/siemens-admq12ee01-eline-12m-wide-angle-pet-immune-pir-p-3131.html
As above have used the above with 6 cats and another customer for 6 months with 2 large labs (now just one, sadly!).
Both monitored systems, set regularly.
  • 1 month later...
If they jump up on windowsills etc within 2 metres of the pir then false alarms will occur. Pet sensors do not cure all ills (salesmen/ surveyors) will say otherwise.
If the client absolutley wants the pets to have free roam then contacts on all perimeter doors/ windows and then confirmedl intervention visual or acoustic via the ARC? Lots of money.
It's a compromise. I would rather if they had pets then focus on a decent security system and keep the pets in the kitchen.
