Hi all,
I'm probably being really dim and missing something really obvious but any help appreciated.
I've installed a Premier Elite 24, simple system, one kepad, 6 contacts. Programming using Wintex.
I've set up area A as all devices for a simple full set.
I was looking to use area B as a night mode which would inlcude 4 of the circuits, just on the ground to allow people to move around upstairs.
I've been through the zone set up and ticked area B on those I wish to include and created a seperate user code just for area B as a 'night pin'.  I've also made sure the keypad is ticked for both areas.
Under the 'Area' tab, under areas, Area B is set to 'Entry/Exit' and under 'Area Arm Suites' to timed exit.
When I set area B it countdown and shows part armed etc, but the system then doesn't re-act when any of the doors are opened.  If I change one of the circuits so it's just on area B it then works.
Is this a limitation of the panel and circuits can only be assigned to one area or have I ballsed up somewhere?
Thanks
Rob
  • 4 weeks later...
There is an answer on the Texecom website, something to do with you have to assign the ccts to both areas. I've a similar problem.
I need a final door set on full set, silent set on night part arm but timed, and then another part arm but as in full set but without a particular cct.
Mind f@ck.
Piece of pi55, do NOT use multiple areas, assign all zones to area A then use the part omit options, tell it what zones you want off in what part set.
