Got called out to this today. Bell faulty and 15 min cut out not working. Removed power and had to leave on battery. God knows how long before that runs out. Told customer to call sign people out so we can access our bell. Can't believe how thick some people can be installing that sign over bell box.
Posted (edited)
Still, I expect it'll last until at least 3am  :smash:
When I went back to an out-of-contract customer having a loft extension last week (I was there for 2 days in the end, in part due to what you're about to read), builders were about to attempt to chop around a twin alert and a smoke by moving them still attatched to the plasterboard!!
Edited by datadiffusion
did you not remove all the sounder connections from the panel?, usually they have a cut off point after 15 mins?
need to knock off power, disconnect panel battery & then disconnect sounder cables, be careful not to touch the strobe connections as these can be around 300V
well that's what id do, always keep a spare sounder, on the other hand its a nuisance so would either do something with the link or even cut the cables from the battery inside the sounder
