Hi all this is my first post on here ,Im looking for a job as an alarm engineer Im currently in a self employed position driving and the job is in a bad way and Im looking to go back to what i used to do.
Ill give an outline to my previous work history and experience I worked for a company in manor park east london from 2004-2006 i started there as a trainee and then worked my way to an engineer ,i was installing texecom premier 816/24/48 ,i was also doing a lot of service work and working on texecom ,menvier ts410 upto ts2500 ,ade optima ,scantronic range.
I know ive been out of the industry for 9 years and Im sure a lot has changed i come from a strong background as i done 2 years of an electrical apprenticeship.
Ive done some cctv installs and the odd access control install ,my weak points are Redcare unit although i have done the bt redcare online training for what its worth.
I have completed 2 cctv installs recently for friends using the Meye app and managed that fine.
I am based in romford ,essex i have my own tools and my own vehicle ,i am in a unique position with my job as im self employed i would even be willing to work say monday and tuesday for nothing just to get as much experience as possible ,i have a clean driving license and no criminal record.
thanks for your time ,i know its a stab in the dark but i though it was worth a shot .
  • 2 weeks later...
Posted (edited)
Hi pal,
Have a job on going in Harlow at the moment and other stuff around London. Give me a buzz
[Edited]
Might be able to give you a trial :)
Sorry admin if I can't post telephone numbers, cannot private message.
Edited by datadiffusion
Contact Details - OP simply needs to make 4 other posts then can use PM system.
  • 2 weeks later...
What sort of work in Harlow, I'm based in Nottinghamshire. Might be a bit too far thanks james
Where abouts in notts are you James?
