Do I need 1K res for EOL
Guest stpatjaxs
Guest stpatjaxs
My manual says I can use the on board resistor or use external 1k res. I think it is only in reference to an eol detector. Specifically, what is an end of line device and do I need these external 1K resistors.
Guest Adrian
B) Have no idea what you are talking about.
But if you tell us what panel and sensors you are talking about we will be able to help you a little further.
Adrian B)
I have to agree with Adrian, it all depends on what equipment your using.
Sounds as though you may have a Galaxy panel though, so if thats the case then yes you must use them.
Wire the sensors as shown below.
Door Contact:
Powered Detectors:
Hope this helps.
Guest kenny james
B) end of line resistors are normally used in conjunction with monitored systems on zones
