removed a samsund PTZ during an upgrade a while ago and finally got around to putting it up at home the other day, but i can't get into the setup menu of it! i'm sure i got into it in the past when i was testing it on the bench but just can't now!
its running pelco P, 4800B, ADD2. i've tried preset 95, 64, and 126 but having no joy. any ideas?
Most pelco I've used you have to set preset 95, not call it.
  • Upvote 1
BINGO! i was afraid to try that incase i 'overwrote' the menu command as most of the other PTZs i've used need 95 to be called.
thanks! :)
No probs
