RichL Posted May 31, 2015 Posted May 31, 2015 Also, if people do let the batteries run down and not replace, with a dedicated MCB it's even easier to just turn the whole lot off to stop the 'annoying bleeping', so that's another good reason to have them on the same MCB as something people can't do without. Agreed, it's a 17th edition thing iirc. Quote Originally said by Charles Babbage On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
PeterJames Posted May 31, 2015 Posted May 31, 2015 Mains smokes are BS5839 part 6 and should be installed to the FRA and certified accordingly regardless of the electrical cert (though this is also required) Quote
