My texecom alarm goes on even if not armed. It happens when I open the door. What is the correct setting for a group that should only generate an alarm when an entry / exit timer has expired. And Only when the alarm is fully armed?
Is it possible to deactivate tamper alarm?
The wiring configuration is set to normal closed. Is that okay? It only happens at the door contact and the kitchen pir. I have 6 other pir and they don't have this issue
