datadiffusion Posted June 9, 2015 Posted June 9, 2015 (edited) Doc what version is that, I don't remember the dc boards being seperate Do you mean the pcb on top and transformer board on left behind it, they did go a bit black in plastic but still carried on working lol Metal version had more room though Its the plastic one with LCD rkp on board, from memory there is the main PCB that sits right out front, then a secondary PCB behind with PSU stuff on?? Either way it seems to be getting hot, hot, hot, although most of the dmaage was probably done in the 7 or so years before I first started servicing it when it had a shonky 'POWERBAND' dead chinoise battery in it. Edited June 9, 2015 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
whistle Posted June 9, 2015 Posted June 9, 2015 (edited) That will be the cheapo abacus 8, same case as the rebel 8. They also did a metal abacus 8. Edited June 9, 2015 by whistle Quote
datadiffusion Posted June 9, 2015 Posted June 9, 2015 You've saved me the bother of actually looking up the customer record, despite me being sat at my actual work PC with all the files open Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
