jkno Posted June 8, 2015 Author Posted June 8, 2015 (edited) PSE would you recommend wiring it up to a spare zone setting it to fault like antinode said? The entire system going off for a non tamper/alarm event seems a bit much. Datadiffusion I wanted a quick disconnect batt/ac fail safe until I tested the system and made sure there weren't any gremlins. Didn't fancy trying to open a 115db sounder with a strobe going off if I had really messed up. Edited June 8, 2015 by jkno Quote
datadiffusion Posted June 8, 2015 Posted June 8, 2015 I would, its an alert you want not an alarm, and certainly better to have one you can rename to make more sense, I.e a zone. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
jkno Posted June 8, 2015 Author Posted June 8, 2015 There's not much information about the fault relay would it just be an open close circuit? Quote
PSE Posted June 8, 2015 Posted June 8, 2015 Connecting to a spare zone and programming for an alert will be fine, Once you've established everything is fine I would revert to the dedicated fault inputs adjacent to the bell terminals. Quote
jkno Posted June 8, 2015 Author Posted June 8, 2015 PSE can you program the fault inputs so it won't trigger the bell and alert the entire street there's a flat battery? Tamper on the bell, key panel, control panel is something to shout about but an issue with the battery that isn't a tamper isn't something that I would want to trigger a full alarm for. Quote
PSE Posted June 8, 2015 Posted June 8, 2015 I believe the dedicated input is fixed, not programmable, can't say I've tried otherwise. Using a spare zone, you could program as custom and select internal sounder only Quote
