I have been advised that apparently it's a straight swap, the terminals are marked up differently but have had it explained to me in detail how to connect it to my Accenta panel :)
The unit mentioned above seems very basic and might not be enough for what I 'might' need in the future, is it expandable, has anyone used/ fitted one?
Thanks everyone for all your advise so far, I really appreciate it.
Ron
I will be suprised if you connect many other outputs, maybe one at the most
Surprised? So what do you envisage the outputs being used for?
I think you should read the original question and then look at general dig and what they fit, many diallera never use there outputs , simply used for notification
So will be suprised if they ever get used by most diy fits , just an opinion
I read it thanks and the OP also mentions in post 11 about its expansion possibilities in the future.
if you want flexibility like that you dont want an accenta and a text dialler, you want a big panel and a gsm unit. ie the siemens spc panel. plus you can use apps on your phone to control, view status etc.
Albeit it isn't an Accenta panel but I regularly use my many outputs via either text or phone call rather than the need for using third party apps which I like to steer away from where security is concerned.
what are you controlling.
i prefer an app rather than sending obscure text message strings.
ie my hkc panel runs my heating and external lighting via its app.
Gates, garages, lights-internal/external, heating, siren, curtains, alarm.
I prefer sending obscure text message strings rather than using an app being controlled by any number of unknowns, servers and potentially risky updates to name 2
  • 1 month later...
