Guest Graham Cawley Posted October 10, 2004 Posted October 10, 2004 Hi - first timer with a small problem. I have the Accenta 6 system in my home. Whilst decorating I removed one the PIR detectors from the wall. This activated the alarm's tamper system so I entered my 4 digit code to silence the system. Now the keypad had gone dead and is not responding. The POWER and TAMPER lights are still illuminated. The mains supply is ok and I have just removed the Mains fuse - when I re-inserted it the siren activated. I was able to cancel it using the keypad but now I'm back in the same position with the keypad not responding. Any ideas please? Graham
Guest kenny james Posted October 21, 2004 Posted October 21, 2004 did you put pir back !!!. you have triggered a tamper fault this is what happens to accentas when you have a tamper fault, at least you have a good starting point.
