sixwheeledbeast Posted February 16, 2024 Posted February 16, 2024 You can't escape without fixing all the faults. Quote
Alarmed-To-Be-Here Posted March 29, 2024 Posted March 29, 2024 Many thanks to all the people providing advice. I have managed to clear all the faults and have exited engineer mode successfully. The issue was with the outside bell wired connection to the board and I had connected to the terminal next to the correct terminal in error - my eye sight isn't what it used to be unfortunately. I then took the advice from al-yeti and used option 21 to set the zone configuration to (CC+Com A/T) from the previous setting (FSL 2K2/4K7). Quote
al-yeti Posted March 29, 2024 Posted March 29, 2024 5 minutes ago, Alarmed-To-Be-Here said: Many thanks to all the people providing advice. I have managed to clear all the faults and have exited engineer mode successfully. The issue was with the outside bell wired connection to the board and I had connected to the terminal next to the correct terminal in error - my eye sight isn't what it used to be unfortunately. I then took the advice from al-yeti and used option 21 to set the zone configuration to (CC+Com A/T) from the previous setting (FSL 2K2/4K7). Good job Fsl will be better if and when you got time to do in future Quote
