No Neutech. Midlands area.
I have sorted the problem. So stupid, can't believe I hadn't realised. The camera comes with a shroud fitted which is used when the camera is hanging upside down from a swan neck. My application was mounted on top of a pole and came supplied with a small visor. The visor was fouling on the shroud on start up as the camera goes through its full range of movement. This then locked the camera up including the camera menus. Unbelievable.
Thanks all for the help.
