I recently swapped out my old alarm panel and installed a premier 88(not elite), I aquired it from a friend who was moving house. The firmware on the panel is only v3.3, so I need to get this updated. it doesn't look like 3.3 has a bell on confirm option, but v10 does. Until I get hold of a flasher, can anyone tell me if there is a way to set the bellbox sounder up as confirmed alarm?
cheers
program any of the 17 outputs on the main pcb as neg applied confirmed intruder the sounder will ring until cut out?
or experiment with a custom output ?
Send an email request to technical,
Ask them to email you the firmware file for V10.02
There was also a later V11.00 from Jan 2012 that had additional changes implemented for PD6662:2010
I have the files, But cant upload them as you're not a Trade member
Get yourself registered here as a full trade member and I will give you a download link for V9.02
The response will be the same from any member on here; if you are in the trade, you already have 5 posts so can apply immediately.
Plus the forum is much more lively in the 'trade' section one of which is available as a non-trade member.
You will only be able to take a v3 panel to v7, v8 boards had an extra nvm chip
