All Premier 88 PCB’s prior to issue 13 were fitted with two 24LC128 in the sockets labelled U9 and U10.
From issue 13 onwards, they were fitted with a single 24LC256 in the socket labelled U10. If the PCB is
prior to issue 13 or has two 24LC128 fitted, they must be removed and a single 24LC256 fitted to the
I seem to remember that there is a year date on the pcb, the year date determines what software can be put in. I know that v8 needed more memory to cope with extra functions/ more log events
There you go, spot on PSE
