joey Posted June 28, 2015 Posted June 28, 2015 Hello all I'm hoping that someone can help me with a an inquiry I received recently from a school that I do work for. They want an emergency alert system that they can activate when an emergency situation arises, for example an unidentified person on site or a bomb alert etc. They are requesting four different sounds to activate or speakers to alert of the situation. Has anyone carried out an install like this? The school has an existing end of class sounder system which activates sounders through out the building however this new system seems to be too sophisticated to add on to it. Thanks Joey Quote
james.wilson Posted June 28, 2015 Posted June 28, 2015 2 tones would be easy, 4 more complex. I'd probably look to go down a pa route and feed tones into the amp. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
goncall Posted June 28, 2015 Posted June 28, 2015 as jimmy says you need a pa system,the inout re play unit will do what you want via inputs and will also replace the class changes sounders too Quote
secureiam Posted June 28, 2015 Posted June 28, 2015 Nexus/Sonos Voice sounders from klaxon signals can give mutipul tones and warning messages if remember correctly may want to check with them as to what they have to offer. Quote
goncall Posted June 28, 2015 Posted June 28, 2015 the problem with tones and 4 different ones they will have to be very distinctive staff will forget them kids will think its class change or fire alarm and will bolt the second they go off,better to go the spoken route ie staff announcement code 100,200 etc and up sell the benefits of a pa system Quote
secureiam Posted June 28, 2015 Posted June 28, 2015 Theres 64 tones on the nexus and certainly some are similar but theres more than 4 distinct sounds (you can try the sounds on there website sample files) and if you can have it so it plays a voice message in between so it is very clear what its for, how it compares to the pa well that's another issue. You can even record your own, don't think you can with the sonos range though. Quote
james.wilson Posted June 28, 2015 Posted June 28, 2015 Tones for new staff etc would be difficult to remember Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
joey Posted June 28, 2015 Author Posted June 28, 2015 Thank you guys for all your input, I have some leads now that I can work on. The Nexus sounders look like what I need, what control unit can I use with these & also how to activate & reset after each emergency situation? Can I install 4 push buttons or hold up buttons to activate each channel? I'll also research into The Public Address system as that would seem to be a viable option too. Thanks Joey Quote
goncall Posted June 28, 2015 Posted June 28, 2015 Thank you guys for all your input, I have some leads now that I can work on. The Nexus sounders look like what I need, what control unit can I use with these & also how to activate & reset after each emergency situation? Can I install 4 push buttons or hold up buttons to activate each channel? I'll also research into The Public Address system as that would seem to be a viable option too. Thanks Joey depends on the existing system,are they using the fire alarm sounders for class change(quite common method) Quote
al-yeti Posted June 28, 2015 Posted June 28, 2015 How about a pa with voice box for prompts and tone for evacuate Quote
