or just a stand alone pa and leave the fire alarm to do its job
Yes absolutely, amazes me that schools use the fire alarm tone for breaks , Muppets , or whoever rigged it up that way
Surely it doesn't conform to BS if they can do that
most do it
I don't know what regs it breaks but why would you confuse the fire tones with break tones unless tones are selectable ? On a fire system , hadn't seen that normally fixed once fitted
like the weekly test,times
for every member of staff? if the current sounders for class change are independent the wiring could be reused for speakers saving a great deal on install costs
What about one per class?
Costs less then a wired install I bet?
http://www.scope-uk.com/products/geo84zwm.htm
My Amateur Radio Forum
Posted (edited)
Doable but have you tried getting anything done with authority it depts
No but can imagine, was imagining a more independent type place though!
Edited by datadiffusion
depends on the size of the school
So what are you saying, a larger wireless pager system is more expensive than a large wired system, or a small wireless pager system is more expensive than a small wired system?
If you are still talking about using an existing hard wired installation then I see your point, but from scratch the wireless will be cheaper.
