Hi All,
Finally getting round to starting the install of the house alarm in prep for each room coming online as and when they are decorated etc.
I have installed the main board and a smart psu with a local keypad for ease of programming etc. I already had a 12v strobe from my old installation but I cant figure out how to get it wired up to the strobes output.
It looks like there are three terminals on output 2 (on the rearmost board) but I only have two wires.
Can anyone help me out with this one please?
'till the next question ...
Thank you.
I also have some branded Yellow sounders/strobes that will be going in later too - making the link to 0v isnt a problem - but which one does the link go to?
So for ease, lets say im wiring in buzzers to the O/P, the negative runs to the O/P Terminals and the positive goes to any of the 12v +ve
  • 4 weeks later...
Forgot about this one, wired it all up using the onboard outputs - and i have put the strobe into the relay.
Does it require a link then from the 0v to the relay (does it matter which part of the relay (left or right input))?
