Im fitting my Pyronix DT PIR's which (in my old house, not installed by me) didnt use the built in EOL resistors but had them all in the panel.
I want to make this one a bit neater and somewhat more "proper job".
Im guessing the clue is in the title - END of Line - that the resistors need to be within the housing of the detector and not within the panel.
I need 1k closed and 2k open - i can get the first 1k from the built in resistors, but my issue now is physically, how would I fit the second 1k resistor into this space...
and does the tamper work on the same 1k/2k principle ?
'till the next question ...
manuals eh .... who'd of thought.
they went with the old house ....
I thought this sensor only gave me just one set of resistors to play with not both,
I'll go google
I have the instructions, but im just a little stuck with the setup here. I had it working fine with a 1k resistor in the panel and the zone wired into the ALM terminals and the ALM jumper set to 1k.
If i move one of the ALM wires over to the TAM terminal as suggested in the diagram the panel reports Open Circuit Tamper (infinite resistance).
I was just being a daffy diyer
With the cover open the tamper caused the open circuit.
closed up the cover and the values kicked in. although i had set 1k and 2k which gave me 3k I quickly fixed it.
Pro in the making here!
cheers all.
